Rear axle 44 or 45 teeth?
CV joints are torn and I have been told to replace rear axles on my 1991. In my quest I've discovered that there are two different types? A 44 & 45 teeth.
How would I know which is correct for my vehicle?
Anything else I should do while this is apart?
86.5 > 95 are all the same....928 Int has rebuilts for about $250 each shaft exchange. Or you can get 4 new boot kits for about $80 if you wish to just regrease the cv joints and install boots does require removal from the car.
