Hirschmann antenna
Can anyone identify this antenna ? Not sure what model but it's huge !! Says part number 6000f851.. It works to, has a porsche part number sticker but very hard to read..don't know what model it's for
It looks like the same one fitted to my 1980, 928 S rear fender.., and as mine is original I,d guess it,s the type that were fitted on all from the start of production to the final cars before the S4 which had the roof aerial.
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
Basic Sponsor
Looks like the standard power antenna fitted 78 to 86 and some 87/88 cars in Australia.
They have not changed that much apart from a plastic case and the price is more like $65 today.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The "replacement" plastic case will work but it really does not fit....comes with the plumbers strap multi holed metal strip to adapt....close but no cigar
It will function which is a good thing.
Basic Sponsor
So Jim what is your solution as I have fitted a number of the "Plastic" versions with total success.
IIRC I bought the last real one from you for my Weissach a number of years ago 8>)
It is an F series 6000,a quite rare hirschmann...bear in mind that every MercedesBenz and BMW from 1973ca to 198x used a power antenna like that, if you're searching for a spare one. Then my and BMW moved to a plastic case 6000u... It is a bit more reliable and they saved weight, the 6000f is very heavy... If you find a 6000d series (unfindable) you will find it weighs about 13 lbs.
