Need some advice, how should I fix this...
In the move from Dallas to Austin in early March everything was going fine until the last 50 miles, started hearing a weird noise then all the dash lights went on.
Inspecting it on the roadside I noticed I lost a couple of belts.
Had to call a flatbed to take the car to the new house. After all the craziness of moving settled down i was finally able to open things up yesterday and get a closer look.
Not sure how it happened but I lost the power steering belt, alternator belt, and the wiring for the fans
![Name: photo 1.JPG
Size: 93.1 KB](https://rennlist.com/forums/attachments/928-forum/833031d1399830192-need-some-advice-how-should-i-fix-this-photo-1.jpg)
![Name: photo 3.JPG
Size: 96.7 KB](https://rennlist.com/forums/attachments/928-forum/833033d1399830364-need-some-advice-how-should-i-fix-this-photo-3.jpg)
Now i'm not sure how to approach a fix...
1.) The alternator pulley and fan are loose, should I replace the alternator or just tighten the pulley and fan? Can tightening these be done correctly while everything is still bolted to the car?
![Name: photo 2.JPG
Size: 75.7 KB](https://rennlist.com/forums/attachments/928-forum/833034d1399830461-need-some-advice-how-should-i-fix-this-photo-2.jpg)
2.) Could the force exerted have messed with my timing, or are there other things I should check out?
3.) The harness next to the 14 pin connector only has 2 brown/black wires and 1 red/blue wire. What was wrapped around the main pulley had 2 brown/black, 1 red/blue, 1 red/yellow. Could the red/yellow in the harness around the 14-pin connector be torn out further down the sleeve, i.e. if i open up the sleeve I should eventually find all 4?
![Name: photo 4.JPG
Size: 64.8 KB](https://rennlist.com/forums/attachments/928-forum/833035d1399830659-need-some-advice-how-should-i-fix-this-photo-4.jpg)
4.) What order do these connect back to the fans i.e. red/blue passenger fan, red/yellow driver? Does it matter which brown/black (I'm guessing this is ground?) goes to which side?
5.) The passenger side connector on the fan appears to be in order, however the driver side the plastic piece shattered. Can this be replaced or do I have to replace the entire fan? Are there other solutions?
![Name: photo 5.JPG
Size: 67.8 KB](https://rennlist.com/forums/attachments/928-forum/833036d1399830876-need-some-advice-how-should-i-fix-this-photo-5.jpg)
6.) the main pulley has some slight score marks, I assume from the wires, is this going to be a problem?
![Name: photo 1.JPG
![Name: photo 3.JPG
![Name: photo 2.JPG
![Name: photo 4.JPG
![Name: photo 5.JPG
![Name: photo 6.jpg
Size: 72.9 KB](https://rennlist.com/forums/attachments/928-forum/833041d1399831472-need-some-advice-how-should-i-fix-this-photo-6.jpg)
I have the entire harness, fans, etc. you need from a 87 928 including unmolested fan connectors.
You can use the fans as long as find a way to properly protect the connector. Heat shrink tubing comes to mind.
It seems like you may have blown a bearing, from the one picture it looks like the alternator pulley is not aligned properly at all to the crank. How much play is there in the alternator pulley? Enough so that when you shake from side to side there is a tapping noise? Some play is normal in them as they wear.
It could be that some wires weren't tied up and sagged just enough to get caught, also walking the belts off the pulleys in the process. It would be helpful if you knew whether the belts severed, or just came off.
It seems the PS belt was shredded and the alternator belt was severed, I have two long intact alternator belt pieces that appear to be cut
[QUOTE=kaelix;11359869]
1.) The alternator pulley and fan are loose, should I replace the alternator or just tighten the pulley and fan? Can tightening these be done correctly while everything is still bolted to the car? If you can get a good grip on the pulley without damaging it (channel lock pliers on a rag wrapped around the pulley) you can tighten it. Just make sure there is a spring washer under the nut. Need to look up the torque spec but from memory it is 40 Nm.
2.) Could the force exerted have messed with my timing, or are there other things I should check out? No
3.) The harness next to the 14 pin connector only has 2 brown/black wires and 1 red/blue wire. What was wrapped around the main pulley had 2 brown/black, 1 red/blue, 1 red/yellow. Could the red/yellow in the harness around the 14-pin connector be torn out further down the sleeve, i.e. if i open up the sleeve I should eventually find all 4? Yes, the wiring is a brown/black to each fan, red/blue to one fan, red/yellow to the other.
4.) What order do these connect back to the fans i.e. red/blue passenger fan, red/yellow driver? Does it matter which brown/black (I'm guessing this is ground?) goes to which side? Do you have access to wiring diagrams? The brown/black doesn't matter.
5.) The passenger side connector on the fan appears to be in order, however the driver side the plastic piece shattered. Can this be replaced or do I have to replace the entire fan? Are there other solutions? I don´t know, but you might make something up with new connectors and shrink tubing. Just make sure the wiring runs in the channel of the fan housing to get it as far away from the belts as possible. The wiring is secured to the fan housing with metal clips. Use tie-wraps as needed.
No problem mon.
No problem mon.
I don't have access to the diagrams, can anyone provide me which wire goes were on the fans?
Ok just checked, it says red/yellow to blower nr.1, red/blue to blower nr. 2. It is logical to assume blower 1 is drivers side and blower 2 is passenger side. Btw also check the fuses for each fan as they might be blown.
Actually, it might not be logical. Cylinder nr. 1 is on the passenger side ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Anyway, it doesn't really matter because both fans work exactly the same at the same time.
I think this is self-explanatory. I held the plugs in the same orientation for all the pictures.
I finally had some time to try and fix the fan wiring, I've got a couple more questions...
The only place that was open today where I could buy wire by the foot was HD, but i'm not sure if I should use this wire. Printed on the jacket (14 gauge seemed to be the closest size):
UL AWG 14 CSA T90 nylon or twn 75 ft1 nom-anc 90C
It also says it's gas and oil resistant, but I plan to use heat shrink tubing to make a small harness for the length I need to repair. My concern is the 90C limit, is it too low?
Where can I find the correct wire in the correct colors?
Also the female terminators I was able to find are different than the original ones, they're missing a metal tab which I guess is to prevent the plastic connector from sliding off.
![Name: fan connectors.JPG
Size: 29.7 KB](https://rennlist.com/forums/attachments/928-forum/846023d1403402915-need-some-advice-how-should-i-fix-this-fan-connectors.jpg)
Where can i find the correct connectors or should it not matter since I also have new boots?
When i lost my alternator belt, it was because my car was way too low (125-130mm, iirc), and the bottom of the alternator had touched the road at 75mph and levered the top mounting bolt right out of the block, mis-aligning the pulleys.
It wasn't obvious at first glance, not until I got to the point of fixing it, so I'm suggesting a very close inspection of all the mounts.
If I had it to do again, I'd use a TimeSert instead of a Helicoil.
Yeah i want this to be a permanent repair, any idea where I can get the correct copper one with the tab? And is 14 AWG the correct size or is there a different size?
