I decided to take the afternoon to clean this POS...
Team Owner
before you get too far into a take things apart mode,
I would strongly suggest to get some deoxit spray and aim the tube into the seat switches,
then do the CE panel ,
you might find the seats work as advertised.
Read this
https://rennlist.com/forums/928-foru...-it-works.html
Read this
I know this doesnt help diagnos the problem, but you can apply power directly to the motors to get the seat into a position so you can drive it in the AM. I use a 12v volt power drill battery, just run a wire from the battery pos and neg directly to the motor contacts. Swap the contacts around to move forward or reverse.
This.
... I had no luck finding any cables unplugged. I can barely get my shoulders in to where I can peer under the seat from the back--even when it's full forward. By the time I get down there, I'm upside down. I can't really get my forearms under far enough to feel for anything either. Guess I've been eating too much spinach...
There are those that have propped a 4' plank from, say, a stool outside the car to the threshold plate of the door opening. Easier to get in and out and less contortion whether you're sitting on it or lying on your on belly or back. Even better if the car is jacked up, or on stands or liftbars.
Have fun.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
You can call me Otis
It's not always what you would suspect. This is what I found to be the problem with mine.https://rennlist.com/forums/members/...ad-switch.html
This.
Have fun.![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Have fun.
When I went out this morning, just for the fun of it, I tried the switches and everything worked. Even though it still was not working when I left the car last night--I kept trying the switches the whole time--it apparently just needed the night to heal. I'm glad I got rid of that problem once and for all.
My passenger window counted to five before it decided to move today. Push the down button (not holding it down)...1...2...3...4...5...down she goes. Worked fine before and after.
Read this
Read this
No planks immediately available last night. I did the head/shoulder/knee stand instead. I can make a video if needed. You have to get in a certain position, and then you just dive into the footwell behind the seat.
I guess I must have dreamt it all.
