Fog light / Bracks
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Hi
I an having some fun with the Fog lights both in the front and in the rear.
Would like ask if any of you have the Wiring-Diagram for the 928S2 from 1984 Auto or any ideas.
The front fog comes on when the Head lights High Beam is on.
Have read the fine document "Fog Lights, Wiring Mod for Full-Time, Early 928"
The rear bracks do not Work well?, aften the car has been sitting in the gagerage for appx. 2 years.
Best Regards
Kim Andersen
Best Regards
Kim Andersen
Electron Wrangler
The front lights that come on with the high-beams are auxilliary high beams - NOT fog lights. These are highbeams (no shield) they should NEVER be on at any other time. Just leave them alone they work properly.
The other lights at the front are the foglights (with shield) - seem they don't come on at all? - they are operated by the switch below the headlights, these only come on when the marker lights or lowbeams are on and will go off when the highbeams are active (USA only).
Is it rear fogs or rear brakes you are having problems with? If this is a USA car you have no rear fog lights...
Did you check the fuses first?
Alan
Alan
Electron Wrangler
Since you are member (already) fill out your signature so we know where you are located and what year you have without you having to put it in every thread. Answeres to many or evcen most questions depend on the year and sometimes the region the car was built for...
Alan
Alan
