Fuel Leak Down Test
Fuel Leak Down Test
I have reinstalled the fuel rails, injectors as well as reconnected fuel lines, and would like to do a leak down test before I fire the car up. Can someone direct me to a procedure? I have searched as well as checked Nichols to no avail. Maybe I am not looking with the correct terminology or syntax. .
Hi GT,
The manual page 24-201 gives fuel pressure (engine off, fuel pump bridged) as 2.3 -2.7 Bar and after ignition off and 20 minutes, there should be 1 Bar pressure remaining.1Bar = 14.5psi
