Smog Pump Diverter Valve Operation
Ok you emissions gurus. The shop manuals are lacking in this area. If the diverter valve sees NO vacuum I assume the air goes to the air box and when the valve sees a vacuum it sends the air to the cats. Is this right or do I have it Bassackward?
Mine has a leak and won't hold vacuum. TIA
Re: Smog Pump Diverter Valve Operation
