Checked fuel lines today...why do they look so new?
Today I pulled the intake tubes and airbox and was surprised to find metal lines all shiny with gold cadmium and soft rubber outer sleeves over the pressed on hard plastic lines. No cracking anywhere. (I do have one new Porsche fuel hose..the cross over line running under the oil filler neck).
The hoses and cad plating look like 3 to 5 year old hoses on a typical car.
The car has 86K miles. It had spent most of it's early life in New York and had just 24K on it in 2004 when purchased by the PO. The PO then used the car as a daily driver until mid 2013. I think most of the miles were highway miles.
Since I can't SEE external reason to replace any of the hoses (in the engine bay), I'm left wondering about the condition of the plastic pressed on hoses (with rubber outer layer). Could they still be toast due to 26 years of exposure to gasoline?
I'm wondering if cars from hot climates are experiencing more of the cooked and cracked hoses, or cars with much higher miles (more heat soaking, possibly in slow traffic). I really expected to see at least the beginnings of checking and cracking. I expected the cadmium plated metal lines to be oxidized to gray.
Looking forward to all the comments that will help others who find their old lines look much better than expected.
The small U-shaped hose is shown in the mirror. I spent some time inspecting this hose from different angles with the mirror. Looks great.
You'll need to change those some day of course but if everything's good, no rush.
But that's me.
What happened to your flex plate is hard to comprehend. Have you checked your crank endplay? The dial gauge with magnetic base (separate items) from Harbor Freight is the best way to do it. I think I paid less than $30 without any discount coupons. I had put all projects on hold until completing the crank endplay check.
Your car looks great. I really like the color.
So I replaced the fuel lines,they looked good at first but they had cracks when I bent them and could have burst at any time because they were over 33 years old.
So if you do not know the age of your soft lines, replace them. That means all of them. Even the power steering pressure hose, as that can burst, spray ATF all over your hot exhaust manifold and catch fire.
Err to the side of caution when dealing with possible sources of fire under the hood of these cars.
But I agree this is one place where its hard to know the condition, and the risk could be high.
If you are really thinking to defer it - try this - buy one fuel hose and replace it - evaluate the one you took off, if its good you have a good reason to leave the rest for a bit - if not do all the rest.
Alan
Alan
We know they fail, the cars catch fire and destroy completely. Heaven forbid anyone is trapped inside when theres a fire.
Change the hoses......all of them IMHO
