928 Forum 1978-1995
Sponsored by: 928 Specialists
Coolant leak
Old Apr 3, 2014 | 09:35 PM
BI928's Avatar
BI928
Cruisin'
Default Coolant leak
I have an 85 auto and appear to have a minor coolant leak where the thermostat housing tube goes down vertically into the block. Is this easily removed, regasketed and reinstalled? If so, any threads that you could point me to would be much appreciated
Thanks!
Old Apr 3, 2014 | 09:49 PM
James Bailey's Avatar
James Bailey
nope....gets somewhat involved. oil fill, intake tubes usually need to come off and the bolts into the heads are often corroded and strip...
Adamant1971's Avatar
Adamant1971
Thanks!
Can be done, but the one Allen key bolt on rear driver side can be a bitch. Just search water bridge removal.
Old Apr 4, 2014 | 01:47 AM
RPetty2's Avatar
RPetty2
Get a "stop leak" at autozone, worked on my car, dads racecar and even my duramax.
Old Apr 4, 2014 | 12:20 PM
BI928's Avatar
BI928
Cruisin'
Thanks much
I'll take a look at it this weekend
Old Apr 4, 2014 | 12:47 PM
Bilal928S4's Avatar
Bilal928S4
I do not recommend using stop leak. More problems will surface.
Old Apr 4, 2014 | 12:58 PM
davek9's Avatar
davek9
don't use Stop leak, just replace the big 'o' ring, you may be able to remove the cross bridge w/o removing the oil filler neck as I recall, by pulling it up and out forward on an angle.
Start soaking the 4 allen bolts now!
You will also need gaskets for the two ends that attach into the heads, good time to also service T Stat.
Old Apr 4, 2014 | 12:59 PM
davek9's Avatar
davek9
deleted
