Used blower fan resistor pack FS?
Mine is belly up
(thread https://rennlist.com/forums/showthre...ferrerid=52583 )
Anyone have a good used for sale?
I do from a 87 S4 with <50k miles - PM me.
Electron Wrangler
Stop calliing it a relay - its a Blower Resistor Pack and the front and rear versions are not the same.
There are several front versions over the years that are not directly compatible (different pinouts) You ideally need one that directly matches or you will have to do some connector modifications (pin swapping).
https://rennlist.com/forums/7570977-post76.html
Alan
Alan
Is it not 928.618.101.01 ,thermo bi-metal switch 88 and earlier and series resistor 89 and later according to PET?
Electron Wrangler
After all - these two names you just quoted are for exactly the same functional item. Functionaly it isn't a Switch or a single Series Resistor or a Relay ... It's a Blower Resistor Pack (or some other 'multiple' adjective). In the wiring diagrams it is called initially a Fresh Air Blower Resistance Unit (~accurate) and later Resistance Group (the latter becoming a worse translation).
Common usage here is Blower Resistor Pack for all years because it's at the same time concise, functionally meaningful and technically accurate.
Alan
Electron Wrangler
