928 Forum 1978-1995
Sponsored by: 928 Specialists
Unused Junction Block?
Old Mar 26, 2014 | 12:06 PM
CoachTom's Avatar
CoachTom
Default Unused Junction Block?
1986.5
5-Speed
Any one know what this Junction Block might be used for? It is under the center console on the right side. There is an after market radio installed but is wired direct to an amplifier in the back of car.
All I can find is a number on the junction block that says it is a junction block 928.615.511.00
Thanks for the help!
TMcD
File Type: jpg
Old Mar 26, 2014 | 12:26 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Door chime or seat belt chime.
Old Mar 26, 2014 | 01:22 PM
Alan's Avatar
Alan
Electron Wrangler
It's a relay socket for that chime relay - if you get a relay you can plug it in - many remove it to eliminate the chimes...
Anyone have a pictue of the later version with 3 relay sockets??
Alan
Old Mar 26, 2014 | 01:33 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
How late is 'late'? Here's the guts of Hebert's '91:
Old Mar 26, 2014 | 01:48 PM
Alan's Avatar
Alan
Electron Wrangler
Rob I'm not entirely sure but it seems there are up to 3 console relays on some cars (Alarm) so earlier than that is likely (GTS doesn't have it either).
Trying to figure out if its 3 of those mated together or a different thing. They look like they interlock (sideways)...? There may be configurations with 2 sockets too...
Alan
Old Mar 26, 2014 | 02:36 PM
CoachTom's Avatar
CoachTom
Thank you for the help...
I thought it had something to do with the radio. I am trying to figure out how this after market radio was installed and why they never wired into the existing speakers, just into the new boom box fabricated for the rear...
It's a mess best way to describe.
TMcD
Old Mar 26, 2014 | 06:53 PM
Leon Speed's Avatar
Leon Speed
Alan
I happen to have the center console out..it started with wanting to install an extended hub steering wheel and well, you know how it goes...anyway, there are three relay blocks on my '89. Left is for the blue relay (alarm?), middle for seatbelt and door chime (originally not there, Louis Ott was so kind to send me his'), right is empty. Not the best picture, but you can see the blocks. Let me know if you need a close up.
Old Mar 26, 2014 | 07:14 PM
Alan's Avatar
Alan
Electron Wrangler
Aryan - Thanks - is this just 3 of the single relay holder blocks mated together? - looks rather like it - but I can't be sure...
Alan
Old Mar 26, 2014 | 07:28 PM
Leon Speed's Avatar
Leon Speed
Yes, three single holder blocks next to each other. Any idea on the right, empty block?
Old Mar 26, 2014 | 07:51 PM
Alan's Avatar
Alan
Electron Wrangler
Aryan
Its for another Alarm relay (USA Only) Flashes the fog & brake lights as well as sounding the horn when there is an alert.
Assume the one you have (blue) is 928.637.160.00 The other should be 944.615.113.00/01 and if you plug one in I'd expect it would work like the USA config.
Alan
