AT shift cable replacement
3rd Gear
The shifter cable I think. The shifter doesn't shift and it was stuck in gear when it (the problem) occurred. Now when I put it in park the car will not start.
Thanks, Jim 84s auto
hi
look under the car at the tranny end and see if the ball has come off the lever on the trans if not see if the lever is moving when the selections are made on the shifter if the lever is moving the cable should be ok
it can be adjusted by taking off the ball end (and pin) and twisting either clockwise or anticlockwise
cheers
Tim 84 s2 auto
cheers
Tim 84 s2 auto
