Need Engine head-block dowels
I need to replace all the pins and dowels that are pressed into the block deck. I had them removed for when I had the block decked for the rat motor, but I do not know what size they are or if I have to be careful about replacing them with basic dowels and pins.
All available from Porsche (AFAIK) and cheap cheap cheap.
2 900 012 070 00 DOWEL PIN - 12x18- block to bellhousing 0.32 2 900 095 072 01 TENSION SLEEVE - 6 x 12 in block on rear of head surface 0.20 1 928 101 195 03 DOWEL PIN/FITTING BUSHING - Block to Girdle 3.76 2 N 013 199 1 DOWEL PIN - straight 6x12 waterpump pin(s)? 0.82 1 N 013 315 1 ROLL PIN 5 x 10 0.31 4 999.012.034.00 DOWEL PIN 3.76 |
Thanks Rob.
How are the heads doing? We are sort of on the same stage right now - the lapping paste should be here tomorrow for me. Then I can start on smoothing the ports and bit and start assembly. I got a digital spring tester from Proform. Hope to get it this week. Bottom end is already assembled. |
I got boxes of these from McMaster-Carr. Cheap and a lifetime supply.
