Steering rack boot
Craic Head
You can measure the distance and replace the tie rods to the same point.
Safest bet is of course to have an alignment done, but it should be pretty much good. If nothing else changed but the boots he should have been able to put everything back together the way it came out.
Depends on how the boot was fitted...I was able to slip new boots on over the ~ 1.5" collar without disturbing alignment - disconnected the ball joint from the steering arm, carefully slide the boot over the joint and down the tie rod.
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
Thanks, i will call to find out, i did notice the steering wheel is a little off center tho. Either way i think i better get it done since the tires are only a year old and also thats when the last alignment was done.
