928 Forum 1978-1995
Sponsored by: 928 Specialists
Would a front tire diameter increase compensate for a front offset decrease?
Old Mar 12, 2014 | 08:06 AM
UpFixenDerPorsche's Avatar
UpFixenDerPorsche
Originally Posted by Hilton
You mean -10mm s.r. to +5mm scrub radius going from ET65 to ET50.
But still, you're right, a 1" rolling diameter change won't make a helluva lot of difference.
Should be enough to make an ET55 boxster wheel nicer to drive on a 928 tho' - the caveat being actually fitting under the front arches without tearing the aluminium as you turn the steering rack. Brief experiment with a 997 wheel (and 997 rubber) says an inch bigger diameter is a lot to fit under there.
Oh gosh oh gee ... there's always one isn't there ... picky picky ... ... (Don't worry Forum. We're acquainted).
+1 re arch clearance.
