928 Forum 1978-1995
Sponsored by: 928 Specialists
removing tachometer needle
Old Mar 9, 2014 | 07:51 PM
yardpro's Avatar
yardpro
Default removing tachometer needle
ii am replacing my drive indicator light.
ii have the tach out of the instrument cluster.
do i just pull up on the center of the dial?
it is NOT wanting to come off, and i figured i would as before i broke it
Old Mar 9, 2014 | 08:14 PM
Guy's Avatar
Guy
Grasp firmly and while applying some upward pressure, rotate it carefully counterclockwise. It is press fited on the shaft.
Old Mar 9, 2014 | 08:16 PM
yardpro's Avatar
yardpro
thanks
Old Mar 9, 2014 | 08:49 PM
yardpro's Avatar
yardpro
BINGO.....
thanks
Old Mar 10, 2014 | 12:53 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
to remove the needles on the gauges use a piece of cardboard placed on the face,
then a fork placed under the needle base if with gentle pressure the needle wont pop off,
try using some heat from a soldering iron on the fitting, then use the fork
Old Mar 10, 2014 | 03:13 AM
danglerb's Avatar
danglerb
Cheap on ebay you can get pullers for watch hands etc.
Link to a not so cheap one with directions.
http://www.esslinger.com/howtoremovewatchhands.aspx
Old Mar 10, 2014 | 07:20 PM
yardpro's Avatar
yardpro
thanks guys....
