My LS hybrid build
#34
No such luck, measured the outside to outside, then subtracted the bolt diameter. Also held a 930 cv up to it and not even close. Those numbers were actual center to center.
#37
Got an email from Oz Chuck on his conversion. Great job on it if you haven't seen it.
http://www.haultech.com/phpBB3/viewtopic.php?f=28&t=586
#38
A lot of those diffs were biting the bullet and blowing out from under the GTOs. Hence the reinforced cover to try to reduce flex and deviation. I don't recall whether that was the whole deficiency or not though, I didn't get quite that deep into my '04.
The anecdotal track record for Torco performing well quieting and preserving those pumpkins is part of where I got my affinity for their gear oil.
#39
Oz chuck, That is the most awesome conversion ever!
No-one will ever top that!- The perfect transplant. 10 out of 10!
Absolute magic!
(love that workshop as well.)
Absolute magic!
#41
Update
Finally got started on mounting the rear end. Managed to get halfway there. Built a mustache bar to mount the back side. Still working on the front mounts. Had to take a break to work on the blue car. In case you're wondering, yes I cut out the rear floor. More on that later.
