March Madness - 87 to 95 Cooling Fans
Basic Sponsor
The cooling fans are becoming harder and harder to find OEM from Bosch.
I have a limited quantity of factory fresh new ones at $225 each. Yes you read that correctly $225 each.
928 624 145 00
If you want to keep your car stock this is what you need.
Once these are gone they will be only sourced via Porsche.
Check prices -----
Pelican = $333.75
928 International = $318
Vertex = $325
Snooze you lose 8>)
Email me at 928sRus - please no PM's
928 624 145 00
Check prices -----
Pelican = $333.75
Vertex = $325
Snooze you lose 8>)
Wow, didn't see this deal coming. Nice Roger.
Email sent for a pair - that should make 5 working fans between SE and GT.
Roger, you may want to consider researching Vauxhall Cavalier 2.0i 8v fans from a 1994/5 model as these are a direct replacement - only mod required is to the electrical connector. The fan blade is different - a better curved blade design with circumferential end fence, however this can be swapped for the older style 928 blade. The fan motor is identical other than the electrical connector.
The same fan motor was used on a number of Vauxhall cars of that era but the above is the only one I can categorically state is 100% correct so much so I'll pay you for one if I'm wrong. My SE currently has 2 fans from an unknown engine size Vauxhall Astra from approx 1989 -1996 !
I do know that back in 2003 ish one cooling fan from Porsche for a 87-95 928 was about £220 (about $350US then) and the equivalent Vauxhall fan was £100 - no idea now but I'll be asking when I'm back in the UK this summer.
