How long until switching to synthetic oil?
I have changed out the oil and went with the Lubro Moly 5W-40 fully synthetic. I swear the car is smoother and quieter, but it is probably all in my head.
I cut the old oil filter in half, to see how much metal was in it. Not too bad, but there was a larger piece of something metallic...maybe 2 to 3 mm in length in it. I guess this is the reason cars have oil filters to begin with. I imagine most of it is small flecks of aluminum from the new pistons.
I'll run this oil 5,000+ miles.
Today my Split Second signal conditioner arrives. I have scheduled Dyno time for September 5th...let's hope I can pull this off without a hitch.
Range Master
Pepsie Lite
Pepsie Lite
John, Quarts or liters? did you put extra oil capacity on as a result of the turbo work? does your car eeally use 9 titers of oil?
