Should I or shoudn,t I ....?
I would disagree with Dave's opinion on the 5 second cranking without letting the engine start. Most of the damage from lack of lubrication in an
ohc engine is in the valve train, which is why you use some moly or oil to coat the cam bearing surfaces and lifters when you rebuild it.
Cranking for a few seconds over and over just lets the oil drain back over and over so it never gets to the top end. Once the engine starts the oil
pump gets the oil up there very quickly minimizing the metal to condition very quickly. Maybe if you have 60w motorcycle oil in the car, or some
goofy viscosity enhancer, you would have more chance of damage, but with the correct oil for the engine in the ambient temp it is in, there
would be less chance of excessive wear by just starting and letting it run. The sooner the oil is there, the better, IMHO. And like Colin said, let it
run for a while at normal temps, not just a few minutes.
(Make sure the garage door is open, of course....).
Just my $0.928. Maybe Greg can chime in on this one and set us all
straight...![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
Kevin
straight...
Kevin
5th Gear
So the argument is that with the engine 'primed' and oil pressure built and oil circulated it will likely/may lead to less wear on startup.
Received 1,609 Likes
The pressure sender is right next to the pump. If the gauge is not registering pressure (and is hooked up, working, etc.) then the pump is still busy building a vacuum to the sump to draw oil. Obviously a worn pump will take longer to suck up oil than a new pump. But, that's in the margin in this context.
Once the engine starts the oil pump gets the oil up there very quickly minimizing the metal to condition very quickly.
During cranking the engine is turning at roughly 100 rpm. At that speed there isn't enough heat from friction to cause wear quickly. (Although, you are causing undo wear on the starter. Of course a starter is easier to replace than main bearings...) But, once the engine ticks over to 1100-rpm shop-cold idle, heat on surfaces with no or little oil film will build very, very quickly.
I for one do not like to see any engine in my garage run for two seconds with no oil pressure.
And like Colin said, let it run for a while at normal temps, not just a few minutes...
Maybe Greg can chime in on this one and set us all straight...
Just in case it's not clear:, I only do the 'priming' when an engine has been sitting for several weeks (or after an oil pan gasket job), not every time the motor is started. Under normal conditions where the engine hasn't been sitting for a couple of weeks it's not an issue.
Dave, you're probably right. Looking at the flow diagram I can see where a
worn pump could delay oil to the main gallery quite a bit in a dormant motor.
Point taken. I think the plain main bearings handle the friction much
better than the no bearing top end, however, and get pressurized oil faster
either way. We may be splitting hairs.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I'm using 15/50 synthetic and the guage shows pressure within a second,
even after a couple weeks of sitting. I remember my 79 being about the
same. Of course in SoCal the car rarely sees temps below 40F. You probably
have much more experience with these motors than I. Might be interesting
to find some factory info on this. Thanks for your explanation.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Hi Shawn, you,re right about the rain, worst year ever here, although us being further North we don,t have the floods they get in the South, we usually get snow, though this year touch wood we haven,t.., and when it does rain it usually freezes soon after, hence tons of salt, thrown around, like it,s going out of fashion.., heck I just think they like putting it down for the hell of it sometimes.
Incidentally what are " Blizzaks" ?
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
Local news this morning advised it's the wettest winter on record.
You guys in California don't know how good you've got it!
Received 1,289 Likes
I would not start it, unless you can drive it for at least 20-30 minutes.
We cannot do that here unless driving on salty road at best. I would never do that with my car.
That way, it's a new beginning every April!
