flashing warning lights and missing
Upon starting my car this morning the red light in the cluster and on the console began flashing. This is new! ALSO I have a miss fire
under load.
My thoughts are since we had a lot of rain here last week and my car sits under a cover under a deck it still gets wet.
I thought if I drove it for a few hours it would clear out and it didn't. Disconnect the battery to re boot and this only helped for about 5min. Added a can off Techron.
Still no improvement
Could it be the "DREADED GREEN WIRE" or could the big belt jumped a tooth?
Yes I use only Chevron gas, my injectors are clean
Plugs are new, wire set is new. I checked all the vacuum hoses
and connections
I have never seen the red lights flash before
under load.
and connections
How's the alternator gauge?
