Virgin 928 owner
Virgin 928 owner
I did it, 81 928 5spd, but at what price! I know Alfa inside and out, but Porsche.... I had a meltdown with the front engine harness, buggered the alternator, stuffed the battery. All is good now. New alternator, new battery and new harness. I'm ok with this, new part another 30 years. Now after several weeks of lovely driving, no spark. Power everywhere, but no spark. Ordered an cdi unit and waiting. Now I have read that a faulty coil can destroy a cdi. So what coil do I get? Is it standard? I might mention, my cdi diagnosis was made easy when I opened it there was water and bad corrosion/rust. I resoldered what I could see and cleaned it up but suspect it shorted out.
Team Owner
Welcome to the club sounds like yout off to a great start
NOTE if your CDI box is stuffed odds are good the green wire is also old,
can be verified by crumbling connectors and cracked outer sheathing
NOTE the green wire is the usual culprit for a non running engine .
if you suspect the coil then you need the correct part,
roger@928srus.com has them
Got the cdi. You know, I don't think I even turned the key and it was running. Happy days. I think I might send my old box to Sydney. It will get a birthday for $350 with a 5 year warranty. As for the coil, I could not locate one nearby. I will get the correct part number or order from 928srus. I know old Alfas run the best when faulty components are replaced with new. The green wire is bright green and looks in good condition. Thanks for everyone's support. Can't wait to drive the car to work. Now to upload pictures?
Chronic Tool Dropper
Very nice! If the rest of the car matches this, you have done well!
