928 Forum 1978-1995
Sponsored by: 928 Specialists
Dull q, sorry.
Old Jan 26, 2014 | 04:13 PM
jorgens's Avatar
jorgens
Default Dull q, sorry.
Hi all.
What`s the constant + wire for the stereo unit on a 81 model?
I saw a overwiew the other day that stated yellow, but no yellow wire in my car..?
Cheers
Jørgen
Old Jan 26, 2014 | 04:18 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Red. black/red is switched if i remember right
Old Jan 26, 2014 | 11:31 PM
Randy V's Avatar
Randy V
25 Year Member
Originally Posted by jorgens
Dull q, sorry.
Thread title failure.
Old Jan 26, 2014 | 11:48 PM
SeanR's Avatar
SeanR
Go get a "test light probe" from Autozone or the like. You can put one end to ground (clip it on to the door jam) and then test each wire in the console. With the key off and it lights up it is a constant. Use that for the radio memory. Turn the ignition on and then test around and find one that only turns on with the key on, there ya go for main power.
Old Jan 27, 2014 | 02:53 PM
jorgens's Avatar
jorgens
I have 2 red, but they are maybe 1mm2 and the ground is maybe 1,5-2mm2. I would have thought that tha main powersupply would have a larger cross section?
Jørgen
Old Jan 27, 2014 | 03:11 PM
Bilal928S4's Avatar
Bilal928S4
Posting pictures of the wires would help people answer your questions better.
Old Jan 27, 2014 | 03:36 PM
Lizard928's Avatar
Lizard928
Get a volt meter and learn how to use it before you do damage.
Old Jan 27, 2014 | 04:27 PM
jorgens's Avatar
jorgens
I have one, and i know how to use it- but I have to wait due to another project before I can connect the battery. Just found it odd that the red + has such a small cross section.
