928 Forum 1978-1995
Sponsored by: 928 Specialists
What will happen if...
Old Jan 25, 2014 | 07:09 AM
jorgens's Avatar
jorgens
Default What will happen if...
I remove this unit, and just disconnect it?
Will I have a constant warning light?
Jørgen
File Type: jpg
Old Jan 25, 2014 | 07:28 AM
928newb's Avatar
928newb
Not sure what that is, but in my car the only things on the console next to the seats are a speaker control of some sort and the trunk release....
Old Jan 25, 2014 | 09:48 AM
Bilal928S4's Avatar
Bilal928S4
I don't know what year your car is, but I think the O2 sensor counter/reset is in that location on later cars.
Old Jan 25, 2014 | 10:38 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
You will have a much better chance of getting helpful info if you give more helpful info - model year, RoW/USA/etc., what the warning light says...
If that is the mileage counter for the oxygen sensor warning light, and if the oxygen sensor warning is what you are trying to turn off:
No one knew how long the first oxygen sensors would last, whether there would be any noticeable symptoms of failure, etc., etc. As a result, Porsche decided to implement a mileage-based warning to service the sensor. The warning has nothing to do with whether the sensor is working or not - it is purely mileage-based. If that is what you are dealing with, there will be no adverse results to disconnecting the switch unit and turning the light off.
Old Jan 25, 2014 | 12:16 PM
depami's Avatar
depami
Originally Posted by WallyP
You will have a much better chance of getting helpful info if you give more helpful info - model year, RoW/USA/etc., what the warning light says.........
Also, your thread title should really be indicative of thread content.
............ The warning has nothing to do with whether the sensor is working or not - it is purely mileage-based...........
That is was my understanding as well but here's an interesting scenario:
My '82 blew all the accessory belts and the first light to come one was the OXS. I assumed it was caused by the lack of air pump belt but how was it sensed?
Old Jan 25, 2014 | 01:13 PM
123quattro's Avatar
123quattro
If your air pump was working, and then it wasn't, measured oxygen in the exhaust changes quite a bit.
Old Jan 25, 2014 | 01:26 PM
jorgens's Avatar
jorgens
It`s a 81 US model, and it`s the "counter" for the oxygen sensor, yes. I do not have the sensor, air pump or cat in the car, just wondered if I would have a warning light coming on if I just removed it- I havent tried yet, due to a ongoing project with changing the dash.
Cheers
Jørgen
Old Jan 25, 2014 | 01:29 PM
depami's Avatar
depami
That's what I figured but the statement by WallyP made me wonder.
Could the warning light be an OR of oxygen sensor and mileage counter?
Old Jan 25, 2014 | 01:56 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Took that out. No light ever.
Old Jan 25, 2014 | 01:59 PM
WallyP's Avatar
WallyP
According to the wiring diagrams and one of the docs (I don't remember which one - sorry) the oxygen sensor light is nothing but a mileage counter, not hooked to the sensor at all.
The only reason that I can think of for your situation is that all of the warning lights come on when the alternator quits with the engine running.
Old Jan 25, 2014 | 04:04 PM
jorgens's Avatar
jorgens
Perfect, thanks!
Jørgen
