Awesome and/or crazy turbo project. You pick.
#48
Now that's impressive! Totally out of the box ideas. I can't wait to see how this one turns out. We currently have a 3.0 2 valve that turns 540rwhp and 550 tq and that's on a mild tune. Do the math, the potential is there.
#50
Captain Obvious
Super User
Super User
Awesome! Always nice to see a home built project. As others said, those weld are good. Way nicer welds than my home made supercharger bracket. Going to let the top of the manifolds stick out of the hood?
#51
Man of many SIGs
The welds on the plenum are a little on the cold side. With it being so cold out (I only keep the shop about 52F when it's 20F outside) it's really hard to keep enough heat in the plenum without overloading the 200a welder. I already burnt up the air cooled torch and made an adapter to attach a larger one. I finally resorted to holding the plenum in front of the salamander to warm it up. I may go over them again later.
Interesting project. I look forward to seeing more of it.
#52
Wow I have some catching up to do. First, I plan on running low boost for a while. That is a cheap ebay turbo. I've made big power on one before. In my experience they have inconsistent quality control. A genuine garrett rebuild kit with 360 thrust washer and a good balance job they hold up just fine. When I get higher in boost I plan on running a comp. The interest to me is the pressure ratio from exhaust to intake. These old design (super T70) turbos have real efficient compressors and it won't have crap for back pressure. What they lack is the ability to spool super fast from using the lightest and smallest parts. They way I see it, my car drove great without boost it's going to only get better. Some 4 cylinder cars like I'm used to working on are boost dependent because they can't hardly leave an uphill drive through without a turbo to help. If I make too much boost too fast I'll just break the driveline or spin wheels. I'm not sweating transient response because I found it easier to very scientifically floor the pedal a half second sooner when I want to go lol.
I'll have downpipe information shortly. Basically it routs down behind the passenger side cylinder head, with the screamer pipe for the wastegate next to it. There's more space than you probably think. The top part of the headers and downpipe will be ceramic coated inside and out. I'm also running dei gold heat barrier on the firewall, back of the intake, and hood. I've had a high mounted turbo on a vr4 setup and the ceramic make it no problem whatsoever. You can damn near lay your hand on it at idle. That being said, I will be running a temperature probe for a while taped to the firewall behind the fuse box.
#53
Oh, the intakes fit under the hood with about 2" to spare. I even designed where they clear the factory cross brace...unless the throttle linkage interferes. The only issue with the hood is the compressor outlet. That's another reason for a cheap turbo to cannibalize until I decide on something better.
#54
By Salamander I'm assuming you mean some kind of kerosene shop heater. Depending on how clean/dirty it burns, holding the plenum in front of it might contaminate your base metal. Cleanliness is so important when working with aluminum. You might want to switch your shielding gas to Helium. Helium makes your arc hotter than when using argon due to it's higher thermal conductivity. Pure Helium is more expensive and it can cause your arc to go funk if you aren't used to working with it. A 50/50 argon/helium mix might be the best for you.
Interesting project. I look forward to seeing more of it.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
#55
Administrator - "Tyson"
http://www.erik27.com/todd/turbo/index.htm
https://rennlist.com/forums/928-foru...deo-added.html
He purposely kept his runners short to reduce low end torque knowing the turbo's would make plenty.
In that dyno chart he reduced the power with the tune to lower the torque in the low to mid range area.
The 16V heads make good torque on their own, IMO going with a short runner like this is perfect.
The 16V and 32V share these components.
The area that is "weaker" with the 16V's has been the pistons ring lands, but I have no doubt this is simply from bad tuning induced detonation.
What is considered a "reliable" power number for 944's these days? 350-400rwhp? If that's the case, then really only two or three 928's have ever surpassed this amount of power per cylinder.
Time will tell.
If and when Todd takes apart the current engine, it will be interesting to see if he is suffering similar issues to high power 951's like cylinders moving around.
#56
I was cramped for space and really wanted to keep the plenum volume up. Then I stumbled across this: http://global.yamaha-motor.com/about...df/44gr03e.pdf
From what I can tell, based on that and my experience, giving the fuel something to bounce off of upstream should actually mix it pretty well. You might already guess I'm not too concerned about my cold start emissions. My car has 315's on the back anyway. It's not going anywhere in cold weather. As far as cold starting the motor goes and dealing with the effect on transient response, ms3 has an xtau compensation factor that is adjustable.
#58
Hacker I totally agree with your comments. I've built many different high performance and/or turbo cars in my past and have found poor tuning at the root of most failures. People are somewhat routinely making 500hp to the wheels from 4g63 engines now with rod bolts, head bolts, and a head gasket. I'm trying to be realistic and keep my goals low, but I think my setup can easily eclipse 500 to the wheels on an inertia dyno. In fact, I think I can pass 450rwhp on the U.S. motor with the U.S. cams. Again, I'm not banking on that yet. The turbo is good for about 750 at the crank...but I won't take it near that far.
#59
I was broken in with working on my eclipse/talon cars. I've seen some crazy set ups and some people running turbos close to the size you are using. Cars that will slide sideways at 70mph due to traction issues with all 4 wheels spinning. That is a crazy sight.
Anyways back to the topic on hand. Any idea how far from completion you are at this point? Also going to do anything with regards to hood vents to help get some heat out of the engine bay?
#60
I'm not sure if or how I will vent the hood. I may copy bensen and widen my fenders out. If so I will blend it in more probably since it's a street car. If I widen the fenders I may attempt to vent the rear of the engine bay into the fender area. I still need to finish the headers, downpipe, and wastegate pipe, fuel lines, wiring, mount the intercooler, etc. I would estimate running in the summer possibly.
If you're already laughing at this point, wait until you see the intercooler size and how it's getting mounted. It's either going to look like, "Look! Jethro mounted that there intercooler" or "Don't F$#@ with me". I'm hoping for the latter.
