Air pump delete belt question
Basic Sponsor
Remove the three fan bracket bolts - add belt - replace bracket. If you have used the correct size belt it will tension nicely.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I did that on my 86.5. I used a green NAPA belt that had made by Gates printed on the back. Get the belt on the engine pulley, then on the fan pulley, and try to lift the bracket up to get one of the three bracket bolts started. Then you can move your hand to a good position to lift the bracket up and square and start the other two...done. You will likely notice there is less high frequency noise from the front with the hood open. The air pump bearings get rough and noisy. It's kinda like when you're in a room with the HVAC blowing and then it stops....suddenly aware of silence.
