solder or electric glue for defroster
Rear defeater connection came loose during repaint. What is best way to reattach? Was going to solder but friend recommended conductive glue.
Mix up a batch of epoxy with metal filings in it. Copper works well, so does brass. Steel/iron will work but not as well.
You can also use one of the thicker "Super Glue" types mixed with filings.
Quick and easy. Works like a charm.
I've fixed several over the years with this method.
Which side of hatch is the wire with this tab? My defroster **** lights up correctly in both positions. It will not time out or defrost the window. I thought this tab could be my problem.
Thomas
Thomas
Hilton,
Could you let me me know which connections are power (+) and which are ground (-) on the rear hatch when you look? I forgot to mark those wires during disassembly
Cheers!
Carl
Cheers!
Carl
