R&R Trans-Axle Mounts
I'm in the middle of replacing half shafts and trans-axle mounts. the axles are out. Now I'm ready to do the mounts. Whats the sequence? Remove the bottom bolts, jack up the trans-axle, then remove the top bolts?
When installing aim for a one mm space between the mounts and the cross member. Also check of any shims were installed/ measure the ga between the mount and the rear cross member and fill up with shims as needed.
