Noise from dash
Noise from dash
I finally figure out why my 928 had no temperature control with heat or AC.. It turned out to be a bad outside air sensor which I replaced with a used unit from 928 International. That did the trick but now there is a noise coming from the dash that sounds like a fan squeal but I do not think it is the blower motor. It goes away when I turn the HVAC to off so it is related.
Is there another motor related to the system that would cause the noise?
Vacuum pod has ruptured. Dwayne has a write up on replacing them.
It may be the regulator (mixer) motor that sits below the pod, above the accelerator pedal.
Does it only squeal when you adjust the temp slider? It is controlled by the sensor loop which explains why it has started working now that you have an outside sensor connected.
its pretty easy to remove and take apart. there are some plastic gears inside that may need some grease
The noise is coming from the pod area and it is my understanding that the blower motor is on the passenger side. Also, the noise does not change when I adjust the blower speed. It is intermittent even with the temperature in a set position as well as the blower speed.
Rennlist Site Sponsor
First thing to try is to disconnect the small vacuum line from the black/blue check valve at the brake booster, start the engine and the HVAC - if the noise is gone, it is probably a vacuum leak. Hook the line back up - if the noise reappears, it is virtually certain to be a vacuum leak.
If it isn't a vacuum leak, the small sensor fan is a likely suspect.
My first dealer repair on my first 928 almost 30 years ago. Squeal in the dash was spoiling an otherwise quiet ride, so I take it in to the dealer and say fix it. $179 for the motor, and $400 labor to R&R the dash and replace it.
Hindsight maybe a long skinny tube and a shot of something like PB Blaster (not WD40 as it doesn't lube very long) down the sensor tube.
There is a plastic fascia on the dash, an air temp sensor, and a small 1" or so diameter duct down to a fan motor that draws air through the sensor. The idea would be small tube past the sensor so the lube sprays on the motor. No idea where it might drip.
My first dealer repair on my first 928 almost 30 years ago. Squeal in the dash was spoiling an otherwise quiet ride, so I take it in to the dealer and say fix it. $179 for the motor, and $400 labor to R&R the dash and replace it. Hindsight maybe a long skinny tube and a shot of something like PB Blaster (not WD40 as it doesn't lube very long) down the sensor tube. There is a plastic fascia on the dash, an air temp sensor, and a small 1" or so diameter duct down to a fan motor that draws air through the sensor. The idea would be small tube past the sensor so the lube sprays on the motor. No idea where it might drip.
Removal of center consul is needed. It is not terribly difficult, but time consuming. While in there take a real good look at the vacuum pots behind consul. Heck, if you are there just bite the bullet and change them. If you don't you can bet one or more will fail soon.
Remove passenger tray and glove box, sides to consul, and cassette storage. remove center vent (2 screws there). This is a start, I am sure there is a write up here (although search rarely works well for me)
