View Poll Results: Does the cruise control on your car work?
Voters: 68. You may not vote on this poll
Naïve idea: is it possible to re-fabricate VDO Cruise Control Amp?
#48
Scott you can have my CC brain, (found it in a box of removed stuff) no need for it in the RS. I don't know if it works, IIRC my cruise was not working when i bought the car with 57K miles. I never looked into why as i didn't care or want to use it so not sure on condition. The car was very well kept though so it may work.
#50
but i believe that internalPCB should be the same, almost.
IMHO,it's not impossible to have these brains perfectly refurbished, unless the big IC inside(late systems of VDO cruise control brain) is gone,it was made on purpose for VDO and it is actually impossible to get.the rest is imho really basic.
I saved my cooling fans brain with 5,50 euro,and 3 euro for the mosfet amp .... this CC brain is far better and less complicated....
#51
1 Post
Motorola manufactured a single chip cruise IC for vacuum controlled systems that would work as an alternative if you can find them.
The datasheet on the chip contains control strategy info for anyone looking to build/program a microcontroller replacement
MC14460
an alternative (I'm currently part way through) would be to replace the whole thing with a GM Delphi module
http://chevythunder.com/cruise_control_system.htm
MC14460
#52
#53
that's great information!thank you for the datasheet!
changing to a chevy brain?not abad idea,but I still prefer to keep the original and work on it, maybe using plastik 70 to protect the board..
#54
If some one could make a guide and parts list to properly replace known problem part that fail that would be amazing and the easier option.
I some one managed to get a newer style and more reliable system to work in their 928 that would give many people a new option to work with.
i can't wait to see where this thread goes.
#55
In answer to your question: Yes.
But now a question re your question: OMG why would want it ???
IMHO (ok ok ... not much 'H' ...) cruise control is for the totally lame and mentally inane nimcompoop drivers infesting highways everywhere.!!! Arrrggghhh.!
As if we're not sufficiently 'brain-dead' already. :-[
I think cruise control is a full-on next-to-dangerous *$@??>*))% that should be banned.
I've disconnected the CC's on both my 928's, and fortunately none of my other vehicles have it.
If you're a driver who is sensitive to ever-changing road conditions and one who is always reading the road ahead this dang thing will drive you mad as it's always doing it's thing according to the rise and fall of the road, whereas mentally you might be reacting quite differently to what you see ahead: so who you gonna trust eh?
Or are you going to turn off your brain and let the CC rear-end an 18 wheeler at 60?
Sheesh.
Sheesh.
#56
That said, the finest CC I have ever used was in my 1995 Chevrolet Caprice former cop car with a certified digital speedometer. It was dead-on constant once set, whether at 35 or 105, up hill and down dale, and a single tap up or down on the stalk changed that speed by 1mph up or down. Two taps 2mph, and so forth. Big torquey LT1 V-8 was a great help in this precision, of course, but it was _much_ better than my Dad's same year 740, which was awful, or the non-op system in my 928.
Last edited by Fogey1; 01-18-2014 at 10:19 AM. Reason: Peace, Jim. You're right about Ohio, I live there and we do a very regular 55 mile trek over a stretch of rural interstate.
#57
Actually I completely agree with you, and we rarely use CC (in spite of ours all working).
There are two circumstances where it can sometimes be useful:
1) You've got a weak radar source somewhere ahead and you need to artificially match your speed to some arbitrary number on a sign; and
2) Ohio.
I'm joking about the second, and the first is way off-topic. But we almost never use the CC and instead just drive at a reasonable speed for whatever the road conditions are at the moment.
Occasionally that leads to a roadside conversation on that topic, but that's just one of the many road hazards that you have to watch for.
I think the real answer is a simple desire that all of the systems in the car work as intended. And that's perfectly reasonable, even if they are largely unused.
The stock CC brain does a good job when it works, and the troubles are for the most part just flaky solder joints which can be fixed, or ordinary parts which can be replaced.
So instead of designing a new one and throwing away the broken unit, why not just fix it?
Modern car repair consists of throwing away questionable parts until the car runs, no one fixes anything. But why not?? Isn't fixing stuff what this group is all about?
Cheers, Jim
#58
I use my 928 as a grand-tourer in the most literal sense of the word. Every summer, there are at least 3-4 days where I drive it all day- meaning, I drive it for as long as I can, then pull over to a motel.
The constant pressure that my right foot has to put on the accelerator does a number on my body. I am not a professional driver, so my body is not used to it. I can feel the effects of driving for long distances without cruise control for at least a week after I've done it. Not so with cruise control.
It doesn't have so much to do with being brain-dead, as it does trying to avoid sciatica. That has a big affect on my profession, and I can't afford to have it.
#59
We actually throw away broken things on the car all the time- things that can be refurbished with some rubber bits and a little work. Clutch slave comes to mind: they can be refurbished, but many get a new one to refresh, for example. Ditto for electric window motors.
As I wrote in the original post, I have two tempostats in my two cars: (only one working) plus five non-working units. (I only have three in the garage, because two I threw away in the garbage after attempting solder reflow.) That's six non-working units in my six years of 928 ownership. I've not encountered anything else so unreliable in 928 ownership. I think it might be time for some different options.
#60
