928 Forum 1978-1995
Sponsored by: 928 Specialists
Which are the interference engines?
Old 01-11-2014, 11:32 AM
  #31
rdisney
rdisney's Avatar
Assume your engine is interference until proven not. Whether its interference by design, carbon buildup, or some other reason. I had a 1980 US Auto I was doing a timing belt and water pump job on. When I turned the engine by hand it would stop with a clunk. After rotating the cams a little I was able to turn the crank a little further. I never investigated why the engine was interference but I don’t recall carbon on the pistons when I replaced the head gaskets and I don’t recall how much carbon was on the valves.
How many reasons might a 16V engine be interference?
Factory “special”
Carbon buildup
Machined heads
Machined engine block
Thin gasket
Old 01-11-2014, 12:24 PM
  #32
tv
tv's Avatar
Originally Posted by Lizard928
All 16V engines are non interference.
All 32V are interference.
This is true for stock in modified cars with no carbon build up.
I'm with this ^
Old 01-11-2014, 03:09 PM
  #33
Lizard928
Lizard928's Avatar
Originally Posted by stuartbrs
My 16V Australian delivered 1981S is definitely interference
That is the 10:1CR 300bhp CIS engine and it would not have been interference from the factory. Someone has done some work internally, or you've got a lot of carbon build up.
Old 01-11-2014, 03:32 PM
  #34
R.Pires
R.Pires's Avatar
So my 83S stock M28.11 is supposed to be non interference UNLESS it has a lot of carbon build up. How can I know that? Is there a way to find out without disassembling the engine? Is there some kind of additive to mix with oil or fuel that can help with the carbon build up?
TIA for your answers.
Regards
Old 01-11-2014, 03:46 PM
  #35
17prospective buyer
17prospective buyer's Avatar
Seafoam works. I've done it on plenty of motors, but you have to realize you need to attack carbon at the cause or source, Seafoam will get rid of it but it'll just come back.
Old 01-11-2014, 04:04 PM
  #36
depami
depami's Avatar
Regards
Quick Reply: Which are the interference engines?
