Oil pump swap Q
Oil pump swap Q
I have a noise I am trying to track down and I suspect oil pump.
I have another engine of same year that I can swap the pump from for a test.
is this OK to do?
is this OK to do?
Team Owner
what was the last thing you fixed?
noise is a rpm dependent "whine". not normal. for sure mechanical, not vacuum or something intake related.
not AC/ALT/SMOG/or PS pump. not Fan. just replaced tensioner, roller, and all belts. WP has only 1500 miles (done by PO in 2009) and is a LASO. noise is concentrated on front of engine in the V.
because WP has low mile I suspect less. local 928 friends Speedtoys and Jim Morton suggested maybe Oil pump.
less timing belt tension = less noise (volume), more tension=louder noise.
oh and it was there prior to my TB work. but its less so now.
Team Owner
was the oil pump removed when the belt was done?
