Official 928 VIN & Option check request thread
#4788
Archive Gatekeeper
I don't have the interior color codes by the individual VIN. But the 1980 Colors and Interiors brochure lists the color codes on pages 8-11. Here's a link to that brochure, you might be able to reverse engineer the code from the interior colors the car has.
https://webfiles.uci.edu/redwards/pu...%20%281%29.pdf
92A0810405
http://www.google.com/search?hl=en&q=92A0810405
1980 5-speed
C02 - 49 state US market
000000 - No engine code but should be M28.13, engine serial # range 810 0001 >5000
G00000 - No trans code, but is likely a G28.05, transmission serial # range 11 05001>09999 (please report back if you can find the serial # of the transmission)
M261 - Outside mirror - plain-Passenger's side, electrically adjustable and heatable
M437 - 6-way Comfort seat left, electrically adjustable, 78-84
M438 - 6-way Comfort seat right, electrically adjustable, 78-84
92A0810405
1980 5-speed
#4789
92A0810405
1980 5-speed
92A0810405
1980 5-speed
Thank you very much for the help, I appreciate any additional information to complete the data of my car!Julio
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyY YD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4 YrLGsKjZRx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWt gWmk6dyISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
#4791
Archive Gatekeeper
WP0JB0927ES862789
http://www.google.com/search?hl=en&q=WP0JB0927ES862789
1984 5-speed
C03 - California market car
M28.19 - engine serial # range 81 E 00001 >05000
G28.08 - transmission serial # range 11E 05001>10000
M027 - Version for California
I158 - Blaupunkt Monterey SQR23 (2 channel)
M185 - Automatic 2 point rear seat belts
M190 - Increased side door strength / Doors with safety bars- US, Canada, Australia
I218 - License brackets front and rear
I464 - Without compressor and tire pressure gauge
I476 - Brake pad with abrasive pad
M481 - 5 speed manual transmission
M484 - Version for USA
M490 - Hi-Fi sound system ( 8 speakers, balance control, 1980-86.5)
M494 - Additional Amp (4x15W, 1981+), Blaupunkt BQA-80
I498 - Deletion of model designation on rear end
M576 - Without rear fog lamp
M650 - Sunroof
I912 - Vehicle without identification plate
1984 5-speed
M650 - Sunroof
MT928 (07-14-2022)
#4793
Archive Gatekeeper
WP0JB0924HS862110
http://www.google.com/search?hl=en&q=WP0JB0924HS862110
1987 S4 Automatic
M28.42 - engine serial # range 81H 05001>10000
A28.12 - transmission serial # range 16 H 00001>05000
I158 - Blaupunkt radio Reno SQR46 - 87-89
I302 - Type designated on rear end
M418 - Protective side mouldings
M490 - Hi-Fi sound system (8 speakers, 1987-88)
M494 - 87-88 Additional amp Blaupunkt BQA 80
M570 - High output (rear) air conditioner
M650 - Sunroof
1987 S4 Automatic
M650 - Sunroof
pcAdam (07-14-2022)
#4795
Archive Gatekeeper
There should be a limited slip diff in this one:
WP0JB0925FS862095
http://www.google.com/search?hl=en&q=WP0JB0925FS862095
1985
M28.44 - engine serial # range 81F 05001>10000
A28.04 - transmission serial # range 16 F 00001>05000
M220 - Limited Slip Differential, 40%
M533 - Alarm
M650 - Sunroof
WP0JB0925FS862095
1985
M533 - Alarm
M650 - Sunroof
#4798
Archive Gatekeeper
Hi russr-
Can you check the digits of the VIN you posted above? Since you're asking from Queensland, I'm assuming you meant WP0ZZZ92ZBS800176, and not WPOZZZ92Z08800176 ? If so, here's that car's info. (Let me know if you meant a different car)
WP0ZZZ92ZBS800176
http://www.google.com/search?hl=en&q= WP0ZZZ92ZBS800176
1981 - Right hand drive
C23 - Australian market
000000 - No engine number but should be M28.10 engine serial # range 801 5001 >8000
A00000 - No transmission code but should be A22.01, transmission serial # range 16 10001>15000
M249 - Automatic transmission
M261 - Outside mirror - plain- left hand side, electrically adjustable and heatable
I282 - Rear sun visors
I413 - Type designated on rear end, gray/silver
WP0ZZZ92ZBS800176
russr (07-18-2022)
#4800
92A0810405
1980 5-speed
92A0810405
1980 5-speed
Thank youJulio
