Official 928 VIN & Option check request thread
#121
Anything on this one:
WP0JB0923HS861708
When I plug it into the above decoder it come back 5 spd. What gives?
Thanks in advance.
WP0JB0923HS861708
Thanks in advance.
VIN: WP0JB0923HS861708
US 1987 928
Motor: M28.42
Transmission: A28.12
Options:
M018 ... Sport steering wheel with elevated hub
I158 ... Radio Monterey 1986 and Reno 1987
I302 ... Type designated on rear end
M418 ... Protective side mouldings
M490 ... Hi-fi sound system
M494 ... 2 speakers on back shelf
I513 ... Lumbar support right seat
I537 ... Left seat with built in memory and lumbar
I538 ... Right seat with built in memory and lumbar
I586 ... Lumbar support left seat
M650 ... Sunroof
#122
Thanks Dave.
#123
It at least means that we don't have info. Possibly that Porsche don't have info either. Maybe that many of those cars were never made. Its probably combination of all three possibilities. All we can do is to try to find missing data.
#125
Archive Gatekeeper
This car is 33 cars older than my '90 GT, which was born on 1/10/90. By any chance is there a 'born on' date on the VIN sticker in ther driver's side door jamb? I'd be interested to know the date.
WP0JB2920LS860245
C03- California
M28.42
A28.16
I400- Pressure cast wheels, I assume this means Design 90's....
M418- Protective side moldings
M474- Sport Shocks
I498- Without rear model designation
M570- Rear A/C
M650- Sunroof
I691- Alpine CD-2 CD player
WP0JB2920LS860245
C03- California
M28.42
A28.16
M474- Sport Shocks
M570- Rear A/C
M650- Sunroof
#128
Attachment 800026
Any additional information that you can provide on this new acquisition would be very much appreciated.
Thanks,
Lance
Thanks,
Lance
Details on the sticker are accurate, but the option blacked out is M220, which is limited slip diff. I can't understand why someone would take an LSD out. It's worth physically checking to see if your car still has the LSD.
Other info
Motor: M28.41
Transmission: G28.13
C36 .. Canada country code.
Options:
139 ... Seat heating left.
158 ... Radio Reno.
220 ... LSD .. blacked out .. check car.
302 ... Type designated on rear end.
418 ... Protective side mouldings.
481 ... 5 Speed manual transmission
494 ... 2 speakers on back shelf.
533 ... Alarm system.
586 ... Lumbar support left seat.
650 .. Sunroof.
#129
1 Post
Dave
Thanks for the look up.
We have it off the ground and did the wheel spin, when we first got it up, just to check, no indication of an LSD, with this information I'll now have to look closer perhaps the clutches are worn out.
If there isn't an LSD it becomes even more intriguing. If the delete was done at the factory, you'd think they would have printed a new sticker, if the delete was done by a PO, they were very thorough to black out the code in the manual.
The sticker in the car is harder to read, but I'll check if it is blacked out as well.
Is there anything else that I can learn about the interior, it is somewhat different from the other 928s that I've seen either in person or in pictures.
Thanks again for the help.
Lance
Lance
#130
1 Post
What specifically should I look for?
I've reviewed
https://rennlist.com/forums/928-foru...ited-slip.html
The only stamping I can find is on the bottom edge of the casing flange, right against the differential cover. On one side G2812 is stamped in, which is different from the G2813 that the VIN describes, on the other is 00507 which I assume is a serial number. It would be interesting to know the history of the tranny.
Reviewed some more, went under with a copper brush and raised a 1 K right in the middle, if what I've read is correct that means the car has an open dif.
thanks,
Lance
I've reviewed
thanks,
Lance
#134
Attachment 800026
Thanks,
Lance
Thanks,
Lance
Just saw this post for info was missed .....
Other info
Motor: M28.41
Options:
158 ... Radio Reno.
650 .. Sunroof.
Other info
Motor: M28.41
Options:
158 ... Radio Reno.
650 .. Sunroof.
WP0JB0921JS860336
Interesting that the transmission is a K-year one ('89). Factory swap? Early warranty work?
#135
His VIN is this:
WP0JB0921JS860336
WP0JB0921JS860336
