Coolant hose dimension
Guys,
I am currently away from the car and need to purchase this coolant hose.
May I ask the diameter and the length of this small coolant hose from the top of the expansion tank to under the oil cap please?
Thank you.
Thank you.
![](http://farm3.staticflickr.com/2893/11722010635_d770c53ab4_h.jpg)
Chronic Tool Dropper
8mm or 5/16" on US cars. I substituted generic fuel injection hose for this duty with good results..
Kevin, the hose you've got arrows on runs from the expansion tank to the coolant bridge - its a factory special item, with different diameters at each end. Save yourself the headache and just order the correct hose, as the end of it at the coolant bridge is about a 12mm ID.
part no 927 106 275 03
The only coolant hoses you can substitute for the 5/16" Dr Bob mentions on a RHD car like yours is the one between the expansion tank and the coolant pressure sensor - i.e. about an 8cm length.
Also, if that hose has failed on your car, then you should be replacing all the coolant hoses while you're at it.
