928 Forum 1978-1995
Sponsored by: 928 Specialists
Heat pours out of console.
Old 04-26-2014 | 12:40 PM
OTR18WHEELER's Avatar
OTR18WHEELER
You can call me Otis
bump for more insight. with pictures. I also have the same issue of heat coming from below. It was not the TT foam or the trans mounts. It was this..
[IMG][/IMG]
with the bell housing removed you can see the firewall heat shield has separated from the beginning of the tunnel, revealing an unprotected gap. The heat shield is a rubber backed foil type, you can see remnants of the glue where it pulled away.
[IMG][/IMG]
Old 04-26-2014 | 12:52 PM
OTR18WHEELER
TT foam
[IMG][/IMG]
[IMG][/IMG]
Quick Reply: Heat pours out of console.
