Turn Signal Wonkiness
I'm having a little bit of an issue with my turn signal/windshield wiper/cruise control switch.
First off, electronically everything is fine. What's odd though is that if I use the turn signal, the windshield wiper stalk also moves. Do I need a new switch or does it sound like something just needs to be tightened up?
It's an odd problem and one that I've never seen before.
Thanks!
Thanks!
Electron Wrangler
Its likely an easy fix - there is a collar that stops the switch body rotating on the steering column.
Unscrew the shroud top/bottom parts and you should be able to see it and tighten the lock screw without any other disassembly.
Alan
Alan
