928 Forum 1978-1995
Sponsored by: 928 Specialists
Alternators
Old Jul 21, 2003 | 11:43 AM
Noelracer928's Avatar
Noelracer928
Cool Alternators
I know many of you say to use only the recommended Porsche Alternators and anything else is a sin. Has anyone else used an alternator other than the Bosche or the Paris rhone. I remember some people using a delco. My question is, can I use something else than what is reccommended if whe outputs (watts) were the same?
Old Jul 21, 2003 | 11:50 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
If your car still has the original alternator, my first suggestion is to find a good auto electric shop - not a standard repair garage, or import shop, an electric shop that repairs starters, alternators, generators and motors. They should be able to repair or rebuild your unit at a reasonable cost. You will be sure that it will fit, and that it will work.
Old Jul 21, 2003 | 11:52 AM
Noelracer928
It doesn't have the origional alternator. It has a Bosch that I found out later is for an audi.
Old Jul 21, 2003 | 12:01 PM
Dozman's Avatar
Dozman
Noel,
I have an alternator out of an 85 shark if your interested. I know its not a Delco. Do you still have the fresh air shroud for the alternator? If not, it is advised to get one and the hose to go with it. I remember someone having a part number for the hose from a Pepboy's or Autozone.
Old Jul 21, 2003 | 12:06 PM
Noelracer928
Originally posted by Dozman
Noel,
I have the 85 and the 84's shroud and I have the hose to. I would most definetly be interested in the alternator. Does it still work or does it need a rebuild?
Old Jul 21, 2003 | 12:47 PM
Rufus Sanders's Avatar
Rufus Sanders
Noel,
I just had my alt. rebuilt at Alternator Rebuild Company, 110 Lake St. Mpls (exactly 1 block east of 35W on Lake)
They did it in 1 day for 85 dollars. Missed ya at Billabongs on Thurs... - Ruf
Old Jul 21, 2003 | 04:06 PM
jpitman2's Avatar
jpitman2
Alternators are ALMOST alternators....not all the same, even if output rating is same. Some measure the V they are charging against internally (IIRC, 'machine sensed'), others have a separate lead from battery, some have a tacho output terminal, sometimes used to keep injection going. We once put a Delco on a Range Rover, but its output was a bit too spiky for the EFI brain, and it misbehaved, had to switch back to original type Marelli.
therefore, YMMV.....
jp 83 Euro S
Old Jul 21, 2003 | 05:25 PM
Dozman's Avatar
Dozman
Noel,
Give me a shout off the board.
psi_101@hotmail.com
