Aftermarket wheel question
I have 1982 with stock 7x16 disc wheels and I believe the offset is 65mm. I've been trying to find out what aftermarket wheels are available for the 928. I've looked into Volk Racing TE-37(43mm offset) and OZ Racing Superleggera(37mm Offset) wheels and they both come in a size of 16x7. What would need to be done for these wheels to fit onto my shark? I don't want them sticking in or out to far of the fender well, let alone rubbing anything. I'm not a wheel expert, so if someone could bring me up to date wheel enhancing that would be great.
Thanks,
Cory J.
Thanks,
Cory J.
Those offsets you mention will not even come close to fitting.
Do a search in the 928 forum on the word 'offset', and you'll get plenty of hits. In the meantime, here's two recent threads chock full of relevant information:
https://rennlist.com/forums/showthre...ghlight=offset
Which style of wheel are you leaning towards?
If you want the biggest tire/rim combo under your car without rubbing or protruding, check my sig. Here's a link to see how they look and fit: (..you'll have to scroll a little bit)
https://rennlist.com/forums/showthre...5&pagenumber=2
