Sigh.. leaking tensioner...
When you rebuild tensioner use a new boot,
put some Loctite PTFE sealant on the adjuster bolt threads,
and also on the one bolt that goes into the oil return port on the block
make sure the inner U boot clamp has the open end facing up.
Note outer clamp will have the crimp section at about 11 O clock when looking at it from the boot side.
Make sure both mating surfaces are clean use Hondabond 4 on both sides of the gasket. install the tensioner.
Use a visene bottle with the tip drilled out a bit so oil can flow,
fill this bottle with STP oil treatment its thicker than gear oil.
after the belt is installed fill the tensioner,
remove both nipples,
fill from the port closest to the right fender,
the port closest to the crank is the vent ,
when oil comes from this port its full .
install the nipples with some PTFE on the threads
I'm starting to use Dreibond at GB's suggestion, not cheap but seems like really nice stuff. I particularly like the comment on the label that "oil assists curing". That's my kind of sealer
The leak is most likely through the adjusting-bolt threads, it needs some sealer. PTFE pipe-thread paste is good, or your favorite gasket sealer. Just put it on the threads, tightening the lock-nut will seal it.
Follow Stan's advice and it should be good. Warming the oil will help also.
I am not convinced about using STP, though. The purpose of the oil is to aid heat transfer and provide some damping in conjunction with the check-valve in the bottom piston. If the tensioner is properly sealed then it won't leak, if not then it will eventually leak no matter what oil is used.
The plastic pivot bushings are a light press fit into the tensioner arm, but should slide on and off the shaft without any drama.
Cheers, Jim
I'll use a thin coating of gasket maker on the tensioner gasket if the surfaces look bent or uneven. The RTV wasn't a "mistake," I don't think.
I see you torqued it right. Overtorque can make the victim part bend.
In any case, I wouldn't worry and I'd leave a repair until it was convenient. Maybe top it up occasionally. The oil lubes the mechanism but there'll be surface coatings if it all runs out.
Says: 1x M8x60 for the bottom-most bolt-way too short
1x M8x45, way too short
2x M8x55, still way too short
