1978 Wiring question
Does anyone have available a simple wiring diagram for the instrument pod on a 1978 928? (I am mostly concerned with the wiring to the the 12 wire connectors)
(In particular the voltmeter and oil pressure gauge are non-functional)
The voltmeter has no response under any conditions and the oil gauge pegs it's self at the high end. (I disconnected the oil sender and then the wiring warning module - still pegs once the ignition goes on)
Thanks for the input; however I did not mention the pod is out of the car now. It is not the contacts, it is in the wiring. Hence, the need for a wiring diagram of the of the three (12 wire) connectors to the instrument pod.
To NEIH
I do not have a personal message configuration set up. Please email me at houread@yahoo.com.
Much appreciated
Much appreciated
