928 Forum 1978-1995
Sponsored by: 928 Specialists
Polyurethane Rear Upper "Banana" Link Bushings
Old 11-27-2013, 02:46 PM
  #61
Lizard928
Lizard928's Avatar
Originally Posted by Carl Fausett
These findings are consistent with the internal limits of the system.
This is the rear bearing carrier, and the bolt that holds the upper link and conical washers in place.
Note the size of the hole provided by Porsche. No matter how much compliance the conical bushings provide, when the bolt hits the sides of the hole - further motion is stopped.
These pictures show how much range Porsche designed in to their system at max, and is consistent with our range measurements also.
You completely miss the reasoning behind the conical washers and why the hole is the size it is. If you note, the hole is actually not drilled/machined, but cast. It's because it is not load bearing. The machined surfaces which the conical washers sit on are load bearing.
  #62
Vilhuer
Vilhuer's Avatar
When system is set up correctly that upper arm bolt will not move at all. Concave pieces on both sides keep it centered and rubber in bushing flexes as much as is needed. Bolt and concave things are not meant to move at all once car is on the road and suspension is in normal driving position. If there were any movement in any other part than rubber entire setup would be build differently. Do not leave concave spacers off.
Quick Reply: Polyurethane Rear Upper "Banana" Link Bushings
