Pkensioner...have a look before I pull the pin
Finally got the Pkensioner and belt installed. Please have a look at my photos for any errors before I pull the pin.
John
John
the plates are used to check timing.
if the oil pump gear was replaced was the nut installed with Loctite and torqued?
install the damper temporary and ensure crank is in position......from the cam gear pics it should be at 45 BTDC
pull the pin and spin then check the extension of the tensioner. all good spin the engine twice then recheck timing; all good spin twice more and rerecheck
Supercharged
What Malcolm said. Remember, it's not like it's a grenade. If you pull the pin, it's not the end of the world. You can lever it back into place using the allen key hole in the pulley and re-install the pin if needed.
Pulled the pin, and have rotated the engine about 6 or 7 full turns. Piston measures 6.7mm (yeah!!!) and I'm showing about 5degrees retarded on the passenger side, and 2degrees retarded on the drivers side. Time to set them to zero!
thanks for the help
John
thanks for the help
John
Put the pin in a safe place. Makes it easy to lock the tensioner back in the compressed position if you need to do future work. No need to hunt around for a suitable wire.
Mike
Mike
Hopefully you put assembly lube and or anti-seize on all the shafts for the gears. They're all keyed and torqued in so they won't slip. However, it makes taking them off much easier and way less frustrating if you ever need to do engine work there again. Corrosion will eventually form and it will suck.
If not, everything's buttoned so don't worry about it since you'll probably not going to work on the front end again in terms of taking off the gears as they look new, except that oil pump gear.
