-84 engine in an -81 car
Hi,
I have a manual Euro 928s -81 with a broken engine so I am replacing it with an -84 engine. Since the new engine has other motor mounts (Volvos in my case) compared to the original, will it still fit the crossmember or do I have to modify/replace it?
Thanks,
Sverker
Thanks,
Sverker
You can use original mounts that are in with -81 S engine. If you want to use later style mounts (Volvos in your case) easiest way is to change entire submember.
Aha, the old mounts will fit? Someone told me I had to get new ones (which I did..). The old ones were just replaced by the PO so then I'll use them intead. Thanks Vilhuer!
/Sverker
/Sverker
You just use everything below engine block from original setup. They should fit straight into newer engine block including engine shock upper mounts.
