I just priced motor mounts for my S4 (has a vibration , new torque tube) at $246 each. They look pretty simple. Does anyone know of cheaper alternatives that will work?
Thanks to the 928 group in the UK we added these to our inventory over two years ago as better alternatives to the failing "Ford" solid MM's.
Plenty in stock for $56 each.
Search is your friend! Check for volvo mounts and email Roger.
The Volvo mounts from Roger are $55 each. There is a pin on them that needs to be ground off for them to fit. The ones I got from Roger already had the pin gone. It's a nice touch.
The ones from the other vendors may have that done too. I don't know. It was just nice to open the wrapping and see that it was already taken care of.
Follow the writeups and you will be fine. Dwayne has a nice one.
They work really well!!! Do keep in mind if you have a supercharged car, your engine will raise up to a hair above stock level and your crossbar won't fit. You'll need to have one made that works.
I know Roger sells them but as we have some Volvo 740 mounts in stock here in the uk I thought I might use them! They look similar but as I haven't had my hands on the genuine porsche ones I can't be sure
