So as per usual, and every other hard to access bolt in this car... i stripped the grub screw holding the rear shift coupler on. Torque tube is removed as of now because it's only 6 bolts and relatively easy, and i'll be installing Lizards improved shifter anyways. I have a right angle drill i was using to try to drill the damn screw out but high speed steel drill bits aren't touching it. I want to just use force to break the damn thing off but i know i can't put much force on the tranny gear selector shaft or else i'll have way bigger ($$) problems to deal with... So what is the best way to get the damn thing off?
I used a Dremel to cut it off, replaced it with a used one from 928 International. Easy.
Heat might work, but this way I got new bushings already installed.
