928 S4 Major service help
Hello,
I have a 1988 928 S4.
The car has been parked for quiet sometime, I am doing a major service soon.
What parts do I need other than injectors, fuel filter, oil filter, spark plugs and change the oil & water ?
Camshaft seals, new rollers, fuel lines ?
Can any one provide me with the part numbers, I am going to buy the parts and do it at a specialist as I lost my faith with the stealership here.
Much appreciate it.
Much appreciate it.
Call the sponsers and they will give you a detailed list.
928 specialists
928 international
928sRus
You will need all the parts to do a TB/WP service and rebuild the tensioner.
All seals for the front of the engine.
Are the motor mounts good?
Is the oil pan gasket leaking?
Change the transmission oil.
Change the differential oil.
Bleed the brakes.
Address all the grounds.
Check the flex plate. Install something stop its migration.
Air filter.
For coolant use distilled water plus something for anti corrosion.
All accessory belts.
That is some of the things on top of my head.
Others please add if I missed something.
928 specialists
928 international
928sRus
Bleed the brakes.
Air filter.
