928 Forum 1978-1995
Sponsored by: 928 Specialists
Jumping into the Shark Tank w/ a no start
Old 11-12-2013, 07:24 PM
  #46
Indy Rev
Indy Rev's Avatar
I did check the tension and adjusted it. It was pretty loose. Brakes work as long as your ready for it to go to thw floor . I blead the brakes sunday and there was a ton of air in the lines. I also found that the pass side front caliper line is clogged. I can't push or vac any fluid out and it holds a vac. I need to pull it and see what the issue is. So the long answer is I'm grilling a steak but will drive it over tomorrow night after work if that works.
Quick Reply: Jumping into the Shark Tank w/ a no start
