928 Forum 1978-1995
Sponsored by: 928 Specialists
Help with Identifying Part
Old Oct 22, 2013 | 09:50 PM
Fnic99's Avatar
Fnic99
Default Help with Identifying Part
I was poking around under the hood and noticed that something appears missing to the left of the upper radiator hose (white arrow). It also appears that there is a ground point there that is not screwed in (gray arrow). Maybe not a ground wire, but looks one. Could someone shed some insight on what is missing here?
Thanks in advance
File Type: jpg
Old Oct 22, 2013 | 09:52 PM
Avar928's Avatar
Avar928
What year is the car?
EDIT:
Just checked my 86. Don't even have those.
Old Oct 22, 2013 | 10:18 PM
Fnic99's Avatar
Fnic99
Sorry, should always include it. 1991 S4 automatic.
Old Oct 22, 2013 | 10:35 PM
the flyin' scotsman's Avatar
the flyin' scotsman
theres a bracket missing that holds the fuel line in place.
the wiring needs some tlc also.
Old Oct 22, 2013 | 10:40 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
It's a bracket to which a -10 Normaclamp (999 511 116 02) that wraps around the fuel inlet line is bolted. Like this, but actually bolted to the bracket with an M6 x 12 bolt.
Old Oct 22, 2013 | 10:41 PM
Bertrand Daoust's Avatar
Bertrand Daoust
Passenger side coil ground?
Old Oct 23, 2013 | 01:21 AM
MainePorsche's Avatar
MainePorsche
There is no ground there.
It is probably the metal bracket that is supposed to be secured in that threaded hole.
Old Oct 23, 2013 | 08:16 AM
Bertrand Daoust
Right. Way to far for the coil ground.
You're right guys. It's a clamp.
From my '91.
File Type: jpg
Old Oct 23, 2013 | 01:46 PM
Fnic99's Avatar
Fnic99
Thanks for the help guys. Should I just let it be or try to replace it?
Old Oct 23, 2013 | 01:49 PM
Bilal928S4's Avatar
Bilal928S4
From your picture it looks like the clamp is there with the grey arrow, just needs a bolt.
Old Oct 23, 2013 | 02:17 PM
Lizard928's Avatar
Lizard928
M6x1 10mm long.
Old Oct 23, 2013 | 06:32 PM
Fnic99's Avatar
Fnic99
Thanks again. I will try to do it this weekend.
Old Oct 23, 2013 | 06:41 PM
Leon Speed's Avatar
Leon Speed
Old Oct 23, 2013 | 07:19 PM
MainePorsche
Aryan,
We are all...
File Type: jpeg
Old Oct 24, 2013 | 03:26 AM
Orantes's Avatar
Orantes
You mean I watched several minutes of Eddie Murphy for that? LOL, I enjoyed it. You're right, there's no ground there.....
