AEM UEGO Install. Am I really running this lean at idle?
I would use a short ground to the nearest chassis point.
If the A/F is really that lean then it means the O2 loop isn't able to hold the A/F to 14.7:1
Have you been through the idle CO setup proceedure in the WSM ?
This install started as a spin off from another thread:
I wanted more information on how my car was running, so I installed an AEM UEGO AFR meter.
The sensor in installed on the unused second bung on my x-pipe, right across from the primary 02 sensor
First reports seem to show me running very lean at idle. This video shows typical with engine warm:
So:
1. Am I really that lean, or;
2. Am I seeing some type of power issue, or;
3. Other?
Secondary question: I left the sensor cable at full length, coiled up in console. It about 8 feet longer than I need. Is it okay to shorten this cable?
So:
3. Other?
Updates: took car for a test drive. Engine fully warm, at highway cruise speed, with cruise cotnrol on to mitigate any manula pedal changes:
Looks lean to me. It does get rich when I mash the gas (not shown).
Also, although I epxected the readout to be "dynamic" I did not expected it to vary that rapidly/erractically. Is this normal?
Attached is a screenshot from a later OBD2 car (via a bluetooth data logger) which has four O2 sensors and two cats -- each cat has a sensor on either side -- so you can see both how well the sensors work (upstream cycles, downstream remains steady because of the cat) and, by extension, whether the cats themselves are working.
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Received 1,643 Likes
At high-loads the target A/F ratio will be around 12.6:1. This maximize power, but results in high HC.
The WOT/idle switch is what tells the LH in which context to operate.
I'm curious as to if you have a specific reason for this statement or if it's just your opinion. Sure the free air calibration isn't fun, but in the years and years of operation of multiple Innovate WB's I've only ever done it once, and likely didn't need to. I was always under the impression that Innovate stuff was the benchmark?
I'll post back regarding any issues, but so far, very pleased with the AEM unit. Fits into OE clock opening with minor work, and at this point I am comfortable that it is showing correct values.
My current plan of attack is to install the new injectors and new O2 unit and then tweak the mixture as needed based on the WSM and Porken's write up in the above link. I'll be buidling a "Blink'r" for the adjustment and will compare those readings with what the AEM gauge reports.
The heater control on the Innovative is very course. That leads to inconsistent temperature in the measuring element. That in tern affects the measured A/F ratio.
Innovative is much much better than not having a wideband. It's just not as good as the other widebands that are for sale.
PM me if interested -
Neil
